04-16-2023 10:10 AM
My SIM card is locked and I don’t know my pin. I don’t understand, I paid for it and i can’t even have access to anything. Public mobile won’t even let me change my email either because to reset the code I need an email but I can’t because that was my old email which I don’t have access to either
04-16-2023 11:52 AM
04-16-2023 10:35 AM
@AyeshaMursal was this phone ever used on PM network? if it is first time this phone used on PM network, very likely it is a carrier unlok PUK you need and you need to ask your old carrier or the carrier you got the phone from to provide you that
And you have another phone to test the PM sim card? if it work on another phone, that further confirm it is NOT a sim card PUK you need
04-16-2023 10:33 AM
I need Puk code but I have not received it. I don’t even remember the message.
04-16-2023 10:22 AM - edited 04-16-2023 10:23 AM
@AyeshaMursal what was the sim card lock message?
Try 1234 and see if it helps, it is the default for all PM sim
For My Account login, please open ticket with PM support:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
