SIM card for iphone 13 pro max
natmocha
changing from an iphone 7 to an iphone 13 pro max .. do i need a different SIM card?
@natmocha  - your Public Mobile account and phone number follow the SIM card, not the phone.
So, simply removing from one phone and adding to another will work in this case.
Remember to set up your phone number in the new phone.
And, consider deregistering the phone number from your previous iphone.
https://support.apple.com/en-us/HT202033
Meow
As long as SIM requirements (physical format) are the same for both phones, no need to get new one.
BeachNBeer
@natmocha  No both take nano SIM. Take sim out of 7 and put in your new phone. Good to go 👍
@natmocha   You are all good.  They both use nano.  No change needed.  Just pop the Sim from old to new phone.
Enjoy your new phone.
