Port-out
Kfriesen1993
I'm trying to do a port-out, but don't have access to my texts. Is there a way to authorize a port-out that doesn't require receiving a text?
7 REPLIES 7
@Anonymous wrote:
also you can try ask another carrier the can accept your public mobile account number then you don't need the SMS,
 @Kfriesen1993 : This is incorrect. The intention is for you to confirm the port-out. The new provider can't do that. Otherwise we'd have port-out frauds all over the place.
@Kfriesen1993
remove your autopay from your account before port out,
for SMS you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent,
  • send a private message to Customer Support Agent by Click Here link,
  • phone number,
  • Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
    • Note: Public Mobile No Support by phone call or Email.. only by CS_Agentprivate message..
         Good Luck..
Verify your identity (publicmobile.ca)
@Kfriesen1993 try to message PM support and hope they approve the port without the text confirmation
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
Kfriesen1993
I don't have the phone with me.
Meow
Could you clarify 'have no access to text'.
Is your phone working? Are you out of cell range? Out of country?
Majority of porting is done replying to SMS with YES within 90 minutes of receiving it.
You would need to contact the CSA's to permit the transfer. Click on the envelope by your purple avatar (nice choice 🙂 ) and click on the little pencil in a box icon and then type CS_Agent in the To box and tell your story. They will ask you all kinds of verification questions. No one likes a fraudulent port-out.
@Kfriesen1993   Generally  you need to reply the Text the port out.  Which provider you are trying to port out and why you cannot receive text or send text?
you are not in Canada at the moment? or you don't have the phone with you?
