11-01-2017 08:29 AM - edited 01-04-2022 02:51 PM
Do the PM SIM cards work with GSM modems? I am trying to register on the network with a PM SIM i have inserted in multiple GSM Modems for Raspberry Pi but the never register.
thanks
11-02-2017 11:43 AM
Thanks. I think I will try another device or change providers which support 2G
11-01-2017 02:38 PM
When you say GSM, are you truly using a 2G GSM device? Public Mobile / Telus do not have such a network on any frequency. Only Rogers does.
For 3G (UMTS / W-CDMA / HSPA), you would need 850 MHz and 1900 MHz.
11-01-2017 11:56 AM
@daddyfix wrote:Thank you that would be great if I could get some help on this.
I have tried to use my personal Cell Phone SIM but its Telus.... Still doesnt register.
So Im thinking that maybe it the SIM and Hardware that won't allow me to register on the network.
Im using the Band 850 on the GSM or should I use the 9600?
The 3G bands should be 850 and 1900 Mhz.
11-01-2017 11:17 AM
11-01-2017 08:47 AM - edited 11-01-2017 08:51 AM
I guess the answer is it doesn't work. This could be due to band compatibility. I take it this GSM modem has all the requisite bands for 3G or LTE connectivity. Perhaps @sheytoon our resident expert in this area can weigh in here.
