SIM Swap
LyndsK
@CS_Agent
new SIM
@LyndsK wrote:
@CS_Agent
new SIM
This is a public forum where an agent will not likely get back to you. WE are all customers like you here @LyndsK .
Did you mean to private message CS_Agent ? If so, go to your envelope and enter CS_Agent in the "Send To" field to connect with Public employees.
@LyndsK
you can easily do it yourself by logging into My Account, using only a desktop or laptop, not mobile as there were glitches
Go to Profile page, then click the pen icon beside sim card and update
https://myaccount.publicmobile.ca/en/account/profile/change-sim-numberhttps://myaccount.publicmobile.ca/en/account/profile/change-sim-number
@LyndsK
SIM  SWAPPING  profile tabs
