04-12-2023 07:11 PM
Hey
I have a new phone but when i put my sim card in it it says i need a sim code to unlock where would I find my code?
04-12-2023 07:44 PM - edited 04-12-2023 07:44 PM
you need to ask the person that gave you the device for the code. you can disable the option for a sim pin afterwards
04-12-2023 07:28 PM
@mac333 what is the exact error message and what phone do you have?
04-12-2023 07:26 PM
I believe the phone should be unlocked
04-12-2023 07:23 PM
its not the PUK yet anyway lol but 1234 is not working
04-12-2023 07:23 PM
it was a phone given to me but is unlocked
04-12-2023 07:16 PM
Hi @mac333
I think your phone is locked. which carrier it was used before? You will need to ask the carrier you got the phone from to unlock it
04-12-2023 07:13 PM
@mac333 wrote:Hey
The default PIN for all Public Mobile SIM cards is 1234. However, if the phone is asking for the SIM card's PUK, you will need to ask a Public Mobile customer support agent for that.
If the phone is asking for a SIM network unlock PIN or SIM network unlock PUK, your phone is locked to another carrier and you'll need to ask the old carrier for those codes.
04-12-2023 07:12 PM
is this a new phone or a phone you got 2nd hand from someone ?
Have you checked to make sure the phone is unlocked ?
