SIM FAILED
briana3
I received a notification that my “Sim failed”yesterday. Since then I have not had cell service. Can you please help me restore service?
CSA_PM
Customer Support Agent
Hello @ briana3,
An agent replied to you yesterday and is waiting for your response.
You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
slusagm
Reseat the sim card with a reboot
or you can ask PM to reprovision the account or sim.
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
@briana3
send  a  private message   To CS_Agent
hi @briana3
if it is a physical sim, try take it out, wipe it clean and put it back in with a reboot
also, try the sim on another phone if possible
if same, you will have to buy a new one.  Buy a new Public Mobile sim from Telus or Koodo or Mobile Klinik or from Amazon.  Then login My Account, go to Profile page and update the new sim card number
