SIM Card and Keep Cell Number
NorineRodych
Hello,
I recently purchased a refurbished cell phone from Mobile Klinik and I would like to know if I need a new SIM card or if I can use my current one and if I can  still use my current cell phone number.
2 REPLIES 2
Chalupa_Batman
@NorineRodych wrote:
Hello,
Just adding on to @Dunkman comments. Another option, depending on the phone itself, you can also purchase an eSIM if the phone allows it. $5 for the first one and then free after that if you need to replace it for any reason. Something to look into. It can be purchased via the Public Mobile app.
Dunkman
@NorineRodych
Yes, you can keep your present SIM card and phone number.  Just need to move it from your old phone to new phone.
If the size of the SIM card is different, let us know
