PUK Code
Doubleagle19735
My SIM is locked.  How do I get a PUK code to unlock my LOCKED sim??
slusagm
PM can help with the sim unlock PUK
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
@Doubleagle19735
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
if you are sure it is a sim card PUK you need, and  the error message is “PIN unlock key (PUK)” or "Enter PUK Your SIM  Card, SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
         open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
          or use this direct link to open Chatbot ticket:  https://urlshortner.tiia.ai/Oyn1L6
            **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you
there.
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
          You have to ask the carrier where you got the phone from for the carrier help unlocking it.
           (Sorry, for this particular issue, PM support would not be able to help)
And If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
      call  Samsung 1-800-726-7864 for a master unlock code.
      The only info you will need to provide is the IMEI and where the phone was purchased
Chalupa_Batman
To get your PUK code, you need to create a ticket to a CS Agent for assistance.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
