05-06-2020 12:26 PM - edited 01-05-2022 11:51 AM
Hi do my text / minutes and data on my plan roll over to the next month ?
thanks
Service
05-06-2020 04:29 PM
Nothing in the plan you purchased would rollover. The only thing that does rollover is any of the add one like additional minutes and the additional 1GB of data that is on a limited time sale right now for $15
05-06-2020 03:57 PM - edited 05-06-2020 03:58 PM
@Asante1 wrote:
It may be a shame about the plan mins/data not rolling over, but since the domestic add-ons do keep rolling over, you should make sure to add $5/500 Canada wide mins to your plan to have the roll over benefit, also currently the 1GB data add-on is also at half price ($15), it might be worthwhile to take advantage of that too as any unused portions of both these add-ons will keep rolling over until completely depleted.
Are you on the $15 plan or the old $10 (expired) plan?
05-06-2020 12:37 PM
05-06-2020 12:32 PM
Plan minutes/texts do not rollover to the next month. Only add-ons rollover until used up except US roaming add-ons expire 10 days after purchase.
05-06-2020 12:31 PM
@Asante1 No, they do not.
05-06-2020 12:30 PM
@Asante1 wrote:Hi do my text / minutes and data on my plan roll over to the next month ?
thanks
If you are on one of the current plans only minutes and data purchased as "add ons" roll over if not consumed.
05-06-2020 12:29 PM
The only roll over that you receive is add ons or promotional add ons. If you do not dip into your add on it will continue to roll over month after month.
Any minutes or data included in your plan does not roll over it will reset to what is included in your plan at the begining of your next cycle.
Hope this is helpful, have an amazing day!
