Where is my banked data?
Now
I chose Public Mobile because of the promise that any unused data would roll over to the next month. I have not used ANY data, because saving it for content creation. I have been subscribed since May 2024. I should have hundreds of G by now. WHERE IS IT?
umnikke8
Public does not have rollover data. BTW for carriers that do have rollover data, they generally only rollover 1 month, so the most you ever get is 2 months worth of data.
Dunkman
@Now
Public mobile has not offered rolled over banked data on monthly plans.   I have been with Public mobile over 8 years and never seen rolled over data plans .
Saying that though, if you purchased a data add on in the past, the unused data on the add on did roll over until used up.  However, PM discontinued this specific add on a while ago since data add on expire after a certain amount of time.
Most Canadian mobile companies do not offer this feature.
Socrates8567
You are mistaken @Now. Public Mobile does not have data roll over. They never have had that. Only data that was rolled over were the Christmas gifts each year which was discontued before you got here.
