01-01-2024 03:45 PM
If I buy a roaming add-on, can I call (voice) from Hawaii to North Carolina?
Add-Ons
01-02-2024 11:38 AM
Thanks, that's very helpful.
01-02-2024 10:20 AM
with iPhone SE 2022, you'll have a volte enabled phone. You'll have no problem calling while in US. BTW...just leave cellular data enabled all the time. As a prepaid cell service, you'll never get a bill for using too much data or anything else. If you don't pre-pay for something, it just won't work. With data, you have a limit and once you hit that limit...data will just stop. You can't be billed anything extra unless you actually buy something like extra data add-on or some such.
01-01-2024 09:32 PM
Sorry, I have it now. I had 'cellular data' off too. Not sure how it made the call.
01-01-2024 09:29 PM
I have 3rd generation SE from 2022, so not so old after all. I turned off WiFi and made a local call, but I didn't see 'LTE', just 'Public Mobile'. Do I have to test with a long distance call, or maybe from the U.S.?
01-01-2024 04:30 PM
which iPhone SE...I have the 2020 and it does work on volte. If you have the 2016, it has volte, but PM won't turn it on.
01-01-2024 04:21 PM
Had to look up VoLTE. My iPhone SE is too old, but I'll try your advice when I get to Hawaii.
01-01-2024 04:01 PM
although PM offers talk while in US, I found that your phone must be volte enabled for best talk experience. In the US, they've shut down their 3G network so calls will work on volte or you must have a phone that will drop to 2G for calls. To find out, disable your wifi, then make a call...does the phone stay connected to LTE or does it drop to 3G for the call ? If it stays on LTE, you're golden.
01-01-2024 03:48 PM
Yes the US roaming covers Hawaii.
01-01-2024 03:47 PM
01-01-2024 03:47 PM
@JohnnyB1 YES
