12-02-2022 12:35 PM
I am writing for my husband..we were away and he purchased two blocks of roaming.We were not able to receive calls or call.
Florida.Sarasota area.
12-03-2022 02:39 AM
@dust2dust . I am away for another week and will trial this setting at home (B.C.) to see if it works.
Otherwise an easy change back at YVR.
Will let you know next Saturday.
12-03-2022 01:41 AM
Great find @RussL ! So at home, did your data work just fine with the prior APN setting? If you're home now, did you change it back or does data still work?
12-02-2022 02:41 PM
Yes home and have written a ticket thank you:)
12-02-2022 02:40 PM
Thank you 🙂
12-02-2022 02:39 PM
yes T mobile ..and verizon etc..
12-02-2022 02:39 PM
@fcottage since you are home now, I guess it is best to just open ticket with PM support and tell them what you have gone through and demand a refund. No worry, they will usually agree to that.
And look like you have trouble opening ticket with Chatbot, then just message them directly here:
12-02-2022 02:39 PM
Thank you so much I went direcly..will see..Again..Thank you
12-02-2022 02:37 PM
Virtual assistant is of no help:(
12-02-2022 02:36 PM
I would think a refund for both blocks is the only solution..hard to contact someone.
12-02-2022 02:35 PM
We are home we tried everything..nothing and we ran into a situation where our phone could have been used
12-02-2022 02:34 PM
Yes but nothing worked.
12-02-2022 02:33 PM
Too late now..thank you..we are home..never worked..We were in range of Verizon..AT and T etc,
12-02-2022 12:57 PM
Similar situation here when landed in Hawaii.
I found this tidbit in the roaming help area and changed:
setting/celluar/Celluar Data Network:
APN: isp.mb.com
to APN: sp.mb.com
T-Mobile instantly came on and "we're in" !
12-02-2022 12:45 PM
Purchased 2 blocks at the same time?
Or 1 block used, then purchases a second add on.
12-02-2022 12:43 PM
@fcottage did you buy only the voice roaming? or the combo roaming add-on as well?
try to connect to T-Mobile network. If it is connecting via Automatic and is not connecting, try to use manual selection to connect
If it still does not work, then yes, open ticket with PM Support and they can provide refund
and to try to able to call home, use workarounds then. Download VoIP app TextNow and make calls using Wifi or Mobile Data for free
12-02-2022 12:42 PM
That is to be expected since USA shut down 3G. Sometimes it works, particularly data, if roaming is set to on and manually connected to t-mobile.
If it never worked, ask agent for refund.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
12-02-2022 12:41 PM - edited 12-02-2022 12:43 PM
Contact a CSA and request credit to your account for un-usable add-on.
editd...
did you try manually selecting T-Mobile as your cell network whilst in FL ?
12-02-2022 12:39 PM - edited 12-02-2022 12:39 PM
Hi there are many issues mentioned with calling problems in the states to try for a credit or refund you need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
