04-11-2022 05:39 PM
Hello,
Do I need to have a plan that includes unlimited calls to the US in order to add the roaming plan that allows me to call US and Canada while traveling to the US?
Add-Ons
04-14-2022 09:08 AM - edited 04-14-2022 09:10 AM
Yes, U.S. data roaming works. Also, Public Mobile isn't only "3g". That confusing way of advertising plans is only about data speeds but nothing about network types. It's possible that a customer has a non-LTE device.
04-14-2022 08:59 AM
Does data roaming in the US even work? 3G was sunset in the US in February and this PM website says "customers with U.S. roaming add-ons traveling to the United States may be impacted when roaming". Of course I read that after I paid for a roaming addon. Public Mobile wouldn't sell me something they know doesn't work, would they?
04-12-2022 01:27 AM
No you don't need a plan that includes that, just the add on which you can purchase on your way there an fit will last for 10 days. Many other alternatives depending on how long you are there, and T-Mobile may be the better network to connect to if you do go the add on route.
04-11-2022 05:53 PM
As long as you have an Active account...you can get a 10 Day US Roaming add-on for use whilst in USA.
Even just the cheapest $15 regular plan and you can still get any add-on.
04-11-2022 05:49 PM
HI @Bb16 Any plan can get US roaming.
How long you will be in US? If you are there longer than 10 days, maybe it is cheaper and easier to get a US Data prepaid plan and then use VoIP app to make and receive calls instead
04-11-2022 05:45 PM
The base plan only needs to be active. Then you buy roaming add-ons for use in the US (not the in-Canada calling to the US). It's 2 steps. Add money to your balance. Buy the add-on from that balance.
