Roaming in U S
03-20-2024 08:50 PM
I recently purchased the 75GB Canada- US subscription. We are travelling to the US soon and I know the plan includes messaging but do I need to purchase additional roaming to make phone calls? ( senior here and not tech savvy)
Add-Ons
03-21-2024 05:42 PM - edited 03-21-2024 05:45 PM
@Loops wrote:Thank you all for your help. Things should work well in the US using the tips you suggested re: connecting to AT and T and using mobile roaming. My iPhone 11 shouldn’t have any problems in the US.
Bookmark this page on your phone so you know what to do if you run into problems. Here's a write up that should help.
How to change Network Operators on iPhone
Press Settings
Press Network Selection
Press the indicator next to Automatic and turn it off.
Then pick T-Mobile for US usage.
Then swipe up and close. It’s best to reboot if possible.
You should be good to go.
Make sure Mobile Data is "green" like you see in the sample and turned on. Also, turn on Mobile Data "roaming on".
Created by Chalupa Batman
03-20-2024 10:54 PM
03-20-2024 09:56 PM
@Loops - You can
- Make calls to an American (United States) number from Canada (Unlimited Calling)
- Make calls to a Canadian (Canada) number with your same regular number while roaming within the USA (Unlimited Calling)
- Send & Receive SMS in Canada & the States (International SMS)
- Use data (75GB) in Canada and the States. (No fees like other providers!)
03-20-2024 09:00 PM
Hello @Loops
No, no need to purchase anything. Let me know what type of phone you have, android or iphone and I'll show you a step by step guide to get you up and running.
03-20-2024 08:53 PM
HI @Loops
the Can-US plan inlcude voice/text/data in US. Basically you use it like you are in Canada
but you have to make sure your phone connects to either T-Mobile or AT&T, manual connect if automatic connect does not work
and make sure you turn on mobile data roaming on your phone
and for voice, what phone you have? for some older phone that is not VoLTE compatible with PM, you might have to connect to T-Mobile and use its 2G for voice
