Roaming Add-Ons
DmitryV
I know that purchased Roaming Add-Ons is not refundable. But my trip is cancelled. Do we have ANY way to tansfer this money somehow that obviously never used
2 REPLIES 2
HI @DmitryV
you are lucky, PM support likely able to reverse it and put the money back in your account as a credit
 please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Chalupa_Batman
Hey @DmitryV
Don't worry about it. YES, they are not refundable but Public Mobile is very understanding and they know life sometimes happens. I'm sure they will be more than happy to add the credits to your account. Just reach them this way.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
