09-07-2022 09:22 PM
Purchased a 10-day roaming add-on on Saturday for my trip to NY from Toronto until this coming Friday, September 9th.
The moment I purchased it, it worked! I could text back and forth with my cousin from her NY house to her NY house. (I was downstairs, she was upstairs, to test.)
Noticed it wasn't working yesterday. Now I can't text her, her sister, or even my family back home in Canada... What happened?
Thanks!
09-15-2022 06:36 AM
Thank you, I may try this, since it didn't work more often than it did. 😕 It wasn't reliable and I was stuck places because I couldn't reach my family.
09-15-2022 06:33 AM
I typed this reply from my email once the issue had been resolved, but it doesn't seem to have posted, so I'll paste here:
Thank you, I think toggling the airplane mode worked. 🙂 Looks like it's working again.
09-09-2022 03:54 AM
open ticket with PM support and ask them refund
At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
09-07-2022 09:34 PM
You can manually choose your network
09-07-2022 09:29 PM
@Danny38 you should be only connecting to T-Mobile or AT&T for roaming
Check your Mobile connection
09-07-2022 09:27 PM
I am still in NY... How do you mean which one I'm connected to? And about automatic/manual?
09-07-2022 09:27 PM
So you purchased the addon on September 3rd. Okay, you are still in the 10 day window @Danny38
Restart your phone or toggle in/out airplane mode.
Are you sure you have data left ? Call 611 to check your roaming data balance.
Both iMessage and Chat Features require a wifi connections or data to send/receive texts.
Disable your Chat Features:
09-07-2022 09:24 PM
Which network are you connecting to ? Try both T-Mobile and AT&T and see which one work. You might want to change from Automatic to Manual so you can pick the one you want
Also, are you still in NY? or somewhere else now?
