Rewards
dian_34
  •  Hi! I made a payment on my plan. I still have not received my points back it's way past 48  hours to receive them. This is the second time I'm posting this. I've put in a ticket I haven't received any help with this problem.
Yes, from Joining Public Points (publicmobile.ca) , it shows 48 hours, which mean 2 days
(4 days is just to setup your Public Point profiles.  If you already on Public Points, no worry about the 4 days)
Reward Points Earned How do I earn it? When do I receive it?
Points Back5% back for every dollar spentEarn points just by paying your bill. For every dollar you spend (on your plan and on add-ons), you’ll make 5% of it back in points. Spend away!Within 48 hours of your spend
VIP_Tech
Hi @dian_34
 It could take up to 4 days to showing in your account,
@dian_34
Hopefully you will get your points before the CS_Agent gets back to you.
LeePublic
Have you logged into the separate rewards website using the same login as your self-serve account?
@dian_34   Yes,  you should get the points within 48 hours.
Did you open a ticket with PM Support last time you had the issue?  Did they have to manually apply?
If you didn't put in the ticket last time, I suggest you put it in now.  Just make sure you waited the full 48 hours already.  To open ticket with PM :
Spoiler
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
