05-16-2024 03:18 PM
03-13-2025 07:28 PM
Thanks! 👍
03-13-2025 07:20 PM
@CatalystOne As it's currently set up, you can only redeem in 15 point increments towards your bill. You can redeem for add-ons for less than the $ value, but that's only useful if you actually need an add on of course.
03-13-2025 07:05 PM
My account shows 23.5 points but under REWARDS section it allows me to redeem only 15 points towards my $35/Mo plan. Shouldn't I be able to apply all 23.5 points?
08-26-2024 09:46 PM
But the point of being with PM was to not pay anything everymonth thanks to their amazing rewards!
Now i will have to pay and also check my account often to redeem stuff, that normally is done automatically.... waste of time and energy !
08-26-2024 08:36 PM
you don't have to check every month, unless you have 15 points monthly. if you don't, just check back every couple months. And also, PM sends you email monthly and tell you the points you have. If you don't need to redeem yet, no need to login
08-26-2024 08:30 PM
I really don't like their new point rewards, it's painful that i have to log every month to check my account!!! I was lucky enought to not pay a dime before (during 5 years) and now with their new sh** changes, i have to pay! It's very annoying !!! Hate telecoms in CANADA !!!
06-25-2024 09:36 AM
I just saw that my loyalty and auto pay rewards have been cancelled. I went to PM because of the low monthly cost vs other providers, seems now that PM has been bought out they don't care to continue low cost service. The low cost brought me to PM and was compensation for all the problems, issues and aggravation I experienced dealing without any real customer service from PM. Now that I will be full price with next to zero rewards, I will switch to another provider that gives real service for a comparable monthly fee. Good riddance to PM.
05-25-2024 02:19 PM
You are right! Like I mentioned in another question response, here in Canada we have a Telecom cartel. No real free market
05-25-2024 02:16 PM
This sounds very helpful! I will check that for myself. Thank you @Phil_Adelphus
05-23-2024 11:25 AM
@DonnaD16 The free data lasts 150 days from when it was placed in your account as far as I know.
05-23-2024 07:10 AM
Thank you for posting the information about losing the data on the $19 plan. I switched over effective next month/billing. I never use data and don't recall being advised I had some free as a thank you for switching to the points system. My question is, do I have the free data they gave until it's used up, then no more? I suppose I could go an look it up myself, but the explanation of things on the site is very vague at best. Thanks for any help provided.
05-23-2024 05:18 AM
Thank you so much for the detailed information. I must have overlooked the email. Have a nice day!!!
05-23-2024 05:10 AM
@Scott_Guo The switch from automatically applied $ rewards to points was announced a couple of months ago, you should have received a notification by text or email and it was also posted here with a link to this FAQ https://www.publicmobile.ca/en/bc/get-help/articles/move-to-public-points
You'll now need to collect points and manually apply them to buy discounted add ons or a bill credit. You might want to look at the new $19 1GB plan at 4G speed that should show as an option for subscription change when logged in to your account (it's not on the general Shop page). You should have received a bonus of data as compensation for the switch so be aware that switching to a lower plan removes that bonus data, but not any previous gift data, as mentioned in the FAQ.
05-23-2024 02:55 AM
I am having the same situation. I used to get charged for $16 plus tax monthly. I am on the $25 monthly plan. I have discounts for $5 loyalty, $2 autopay, and $2 friend referral. But this month I got the bill ($25 plus tax). Is public mobile no longer offering the discounts? Does anyone know?
05-18-2024 08:17 AM
05-18-2024 08:12 AM
It is set on LTE/WCDMA/GSM (auto connect) and only have the 3 other options I mentioned earlier.
05-18-2024 08:08 AM
@DonnaD16 I think you were looking in the wrong place for automatic, it's not for the speed (you didn't mention LTE which is why I thought the phone was old but S10 should have LTE). See the instructions from Samsung that I just posted.
05-18-2024 08:05 AM
It's not more than a few years old. It's a Samsung Galaxy S10
05-18-2024 08:03 AM
@DonnaD16 It should have LTE then, if you tap on automatic in networks does it not switch to manual? See this article from Samsung, you should just be able to toggle off Automatic and select a carrier
05-18-2024 07:53 AM
Really don't think it's that old. My daughter gives me her old phones every couple yrs when she upgrades. Its a Samsung S10
05-18-2024 07:51 AM
@DonnaD16 What phone is that? It sounds as if it's fairly old?
05-18-2024 07:42 AM
Thank you for the suggestion, but I don't have a manual option in my settings. I only have auto connect and WCDMA/GSM, WCDMA only and GSM only. My phone is set on auto connect with Public Mobile as operator.
05-18-2024 12:44 AM
@DonnaD16 You could try setting the network selection to manual instead of automatic and then selecting Public Mobile to see if that helps.
05-17-2024 04:52 PM
Yes and taking away credits after receiving them for 3 yrs is not good business practice. Sure they now reward us with points but it'll take 8-9 months to get enough points to apply ti the bill. Then you have to start all over again. Geesh, how gullible do they think we are?
05-17-2024 04:48 PM
I've seen a lot of recommendations for other carriers since I posted. My main issue was dropped calls too. I understand that Lucky Mobile is owned by Bell which I will never deal with again. I'm going to give PM another month and if calls keep dropping, I'm moving too.
05-16-2024 09:10 PM
yes but switching to Lucky Mobile does... Plus they have better coverage anyway. All i get is call drops with Public and texting doesn't go through sometimes, horrible.
05-16-2024 08:40 PM
Honestly I don't know what the lowest basic price is. I only want Canada wide calling and unlimited texting. Apparently my plan was $25 but I had loyalty credit and automatic payment which brought my total plus tax to $22.60.
05-16-2024 08:36 PM
You're right that it is even cheaper than I'm paying now but that will increase to $21 monthly after 90 days which will being it to a bit more than I'm paying now. As for the Telus kiosk, I was in there last week and the pimply faced kid offered to move my service over to Koodo at no charge whenever I'm ready. If I have a real problem with my phone or service, it's much easier dealing with someone face to face than sitting with my cell phone waiting for an acceptable resolution. But I am going to give the new plan a chance.
05-16-2024 08:01 PM
05-16-2024 04:32 PM
I have the same issue, I was paying under $9 a month and now I am paying over $16 for the same crappy service. I don't need much data, i want bare bones for emergencies.
