Rewards
03-29-2024 11:26 AM
03-29-2024 01:10 PM
Just do something else if you do this for money. Doing anything else, you can make much more.
03-29-2024 01:01 PM
Spend (a lot) of time answering questions and help other customers.
If you answer is helpful you might get a Bravo. If it really helps somebody that person might accept your answer as Solution. Then PM will apply very secret formula and select lucky ones for rewards.
03-29-2024 11:38 AM - edited 03-29-2024 11:38 AM
Hello @Awesome_guy
How to earn community rewards
Want to learn more about how to be a top contributor?
Getting started is easy. All you have to do is give help to your fellow Community members, acknowledge solutions, and share ideas. And, of course, your suggestions and feedback will help us create a better experience for everyone.
Here are the levels
Just know you will never get $20 unless you're an Oracle, which can take possibly years to become if at all.
To get $15 you have to be extremely active.
To get $10 you have to be very active.
To get $5 you have to be active.
03-29-2024 11:33 AM
By helping other community members on the forum. The exact formula for awarding community rewards is not known to us. Likely a combination of number of posts, bravoes received and solutions received.
Probably not worth your time if you are just interested in the money part. To receive the higher points rewards, you will need to spend more time. Way less than minimum wage. If you enjoy being part of an online community and helping others, then participate as much as you can.
Here is some more information:
https://www.publicmobile.ca/en/ab/get-help/articles/public-points
03-29-2024 11:31 AM
@Awesome_guy It’s a secret formula that only PM knows, what I can share is that
By participating , reading and helping others with questions . And learning and sharing and good things will happen
ranked chart here
