Rewards system
Happyliu
How do I change back to the old rewards system? If I change back , do I have to use my points first?
Happyliu
Thanks
@Happyliu   sorry, no going back.  Many asked  but PM made it clear and made no exception.
@Happyliu
Unfortunately, once you switch from the old Rewards system to the new Points system. You can’t switch back.😭
Happyliu
Thank you
@Happyliu  Sorry you cannot go back to the old rewards , it’s a one way street
