Reward
04-11-2024 02:28 PM
Hi, referred a friend over two months ago but I haven’t got the one dollar reward yet. When should I get the reward? Also my friends hasn’t gotten the $10 Credit yet. Thank you.
Rewards
04-11-2024 02:34 PM
HI @chunguang
if 2 months, that is too far away. But you are on Public Points? maybe you have more than 1 friend and happened that one friend just left when this friend joined?
you can ask PM CS agent to check your friend referral history. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
04-11-2024 02:34 PM
check to see if your friend received the $10 in his/her account or not. If not, you might want to ask your friend to help to submit a single ticket for both of you
open ticket with PM support:
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
