Return phone
Tazzo
I just bought a phone from public bout a month ago now my screen is broken what to do to send it back?
DDM69
If you broke it you’re out of luck. Send it to the dump.
@Tazzo
Very slim that PM will cover damage screen if was accidentally dropped.
You will need to bring it to a cell repair shop to have it replaced.
will13am
The warranty is for manufacturer related damage, not personal induced damage, misuse.
Metal1967
@Tazzo  Define broken.. if it’s cracked etc  not likely you’ll have warranty..
@Tazzo   was that within 30 days?  I think the full refund is just within 30 days but there is a one year warrantly
Don't want, open ticket with them today.  Since chatbox usually have problem with CPO tickets, please direct message them with your order number :
