data no working:(
FranklinR
I bought the 25$ plan and I cant use my data. I used airplane mode and reset my phone twice so idk what it could be
noaccountpls
Hi @FranklinR
Do you have an iPhone? if you do Please try to reset network Setting
https://support.apple.com/en-ca/HT201415
will13am
@FranklinR , usually APN settings are the problem when data is not working.  Use this link for APN set up.  Check also that mobile data is enabled and the usage limiter is not triggered.
https://productioncommunity.publicmobile.ca/t5/Get-Support/How-do-I-set-up-data-APN-on-my-smartphone...
dust2dust
Are you new here? Or did this just happen? Did it work before? It's likely an APN setting. What make and model of phone?
