01-02-2021 11:35 AM - edited 01-05-2022 04:41 PM
Hi, if I don't remember email and password that I have used to login. Is there a way to retrieve it?
Thanks
01-02-2021 11:52 AM
@Kp11 wrote:Hi, if I don't remember email and password that I have used to login. Is there a way to retrieve it?
Thanks
PM sent you a welcome email after activation. Check your email accounts for the welcome email.
If you find the welcome email, your can use the Forgot your password? link on the login page if you remember the answer to your security question.
If you do not remember the answer to your security question, Create a moderator support ticket for help using https://publicmobile.ca/chatbot. Tell SIMon what is the issue (important) - Use "forget password and answer to security question".
To verify that you are the owner of your account, use your account PIN #.
If you forgot your PIN#, provide any 3 of the following:
- Complete mailing address,
- Email address,
- Alternate phone number,
- Date of birth,
- Last top up date & amount
01-02-2021 11:39 AM
You should have received an introductory email from Public mobile when you first signed up.
Have you tried reseting your password.
https://selfserve.publicmobile.ca/forgot-password/
(Check your junk folder)
If not working, you will need to contact moderator.
To contact moderator via 2 methods:
Click on the blue chat bubble icon on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
or
2 Send a private message to moderator through the following link :
01-02-2021 11:38 AM
You would need to submit a ticket.
Here’s when and how to contact the Moderator Team:
