Resetting my PIN
06-14-2022 11:37 AM
06-14-2022 12:34 PM
HI@dust2dust I did. I did type it out once in the beginning 🙂 (No, I didn't copy and paste from any other member)
I always use "forgot..." for both My account login and PIN reset myself and proved to work, but just tried "Reset Pin", and it works, too . So, I will make my update in the future
06-14-2022 12:17 PM
If you are talking about PIN used in PM, only agent can reset it for you.
Get new PIN ready as agent cannot tell you your current one - they can only update it.
06-14-2022 11:51 AM - edited 06-14-2022 11:52 AM
@Gunner123 It is not a copy and paste.
I typed it and tested it
It will make SIMON route you to the proper type of ticket opening. Reset PIN and Reset Self-Serve password is classified as the same type of ticket.
Test it out yourself.
06-14-2022 11:45 AM
@hTideGnow why type forget login information? copy and paste?
06-14-2022 11:40 AM - edited 06-14-2022 11:40 AM
HI @Red84 Only CS Agent can help to reset the pin, please open ticket with them at : https://publicmobile.ca/chatbot.
Follow this to get to ticket open screen quicker:
- First type: "Forgot log in information"
- Then Click "Contact Us"
- Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
06-14-2022 11:40 AM
1. hi you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type reset pin
2. alternatively you can private message them here
