12-30-2023 10:13 PM
the eSIM was not installed in my phone. May you send me the QR code for eSIM? thanks
12-30-2023 11:13 PM
tried but still did not work
12-30-2023 10:45 PM
@Ryaan wrote:I have a QR code in my email. when I scanned and installed it, it says "Unable to Activate eSIM" in the new iPhone 14.
@Ryaan , have you tried these steps below? It worked for me to activate eSIM on my iPhone!
Reboot your phone.
In cellular settings make sure that ‘Turn On This Line’ is selected & reboot your phone. (You may need to reset network settings then reboot)
I tried 3 times to respond & it keeps getting deleted!
12-30-2023 10:42 PM - edited 12-30-2023 10:42 PM
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
12-30-2023 10:40 PM
How to contact PM support to regenerate a new one.?
12-30-2023 10:35 PM
how to regenerate new one ?
12-30-2023 10:32 PM
@Ryaan so, nothing installed by the app? check Setting > Cellular screen once more
If not, you might need to ask PM support to regenerate you a new one.
12-30-2023 10:30 PM
12-30-2023 10:27 PM
What kind of phone do you have?
12-30-2023 10:26 PM
I tried to install eSIM from QR code in from email, but could not activate it.
12-30-2023 10:25 PM
It was unable to be activated
12-30-2023 10:25 PM
If you don't have one in your welcome email you will need an agent to approve a credit for a physical Sim card so you can gain access to your self serve account. Then if you still want the esim the agent will credit it too once you purchase it.
12-30-2023 10:21 PM
sometimes the app might have already installed the esim on your phone. Check the SIM manager or Settings > Cellular
If not, check if you got any Welcome email from PM, there is a QR code there
12-30-2023 10:15 PM
@Ryaan Check your welcome email for the QR code and you can scan it with phone to instal if . If no luck submit ticket with support
send a private message To CS_Agents
