12-30-2023 07:21 PM
I just joined today. It said it may take up to 5hrs to activate. It’s been over 5hrs and I still have no cell service. At the top corner in my phone it says SOS.
12-30-2023 11:08 PM
Thanks for the advice. I did restart the phone three times but didn't work.
I tried to configure APN setting but my phone doesn't display 'cellular data network' in settings. I wonder if this means the e-sim wasn't installed properly? I tried to reinstall using QR code that was sent by the public mobile but it doesn't work either.
12-30-2023 10:36 PM - edited 12-30-2023 10:46 PM
Restart your phone. Sounds stupid, I know, but it is necessary when using a new SIM.
And login to your Self-Serve. Check the account and service status. Click the "activate" button manually if it didn't happen automatically.
And you will not be able to access data (or MMS messages) if your phone isn't configured with Public Mobile's APN settings. Newer phones might do this automatically, but not all of them can autoconfigure pushed APN settings so you might have to do it manually (and restart, again).
eSIMs rely on software (Public Mobile app) which physical SIM cards did not require. So eSIMs are subject to software bugs, problems, issues which do not affect physical SIM cards. Restarting or rebooting the device is usually the magical panacea for strange software malfunctions.
12-30-2023 09:55 PM
12-30-2023 09:53 PM
btw, my son and I both joined today. Both phones don't work.
12-30-2023 09:52 PM
I did submit the ticket with the link you provided. Thanks. It is so frustrating. I can't call or text to anyone. My phone doesn't connect to internet using the data. I tried everything the chatbot suggested but didn't work. I wonder if submitting ticket will do anything. If I don't hear from the public mobile within a day, I am going to switch back.
12-30-2023 08:01 PM
@seven_mj08 You too can use the link in my last reply to submit ticket it’s direct link to support
12-30-2023 08:00 PM
I am having the same problem. I tried to submit the ticket and didn't work. 404 error. My previous carrier already unlocked my phone so I don't know what is wrong.
12-30-2023 07:25 PM
@Jodi-D You need to submit ticket with support if you have been charged already and get them to re provision the SIM
send a private message To CS_Agents
12-30-2023 07:23 PM - edited 12-30-2023 07:24 PM
Hey @Jodi-D .
This is how you sign up. You followed these instructions?
How to sign up with Public Mobile
Also, did you do the eSIM or had a physical SIM card? If you used an eSIM, you may need to go into your settings and chose it as your primary SIM and then reboot. You should be up and running.
