Renew my plan earlier
09-08-2018 12:45 PM - edited 01-05-2022 05:38 AM
Hello,
I have enough money at my account and I need to renew my plan earlier - what can I do? I'm hurry, please help me asap.
Thank you!
Payment
09-08-2018 01:33 PM
@KMG yes only mods can renew early.
09-08-2018 01:26 PM
@popping wrote:If your account status is active, you can renew you plan earlier.
1. Login to your account and check account status = Active.
2. Click on [plan and add-ons] tab
3. Click on change plan button
If you account is suspended, send a private message to modertor for help.
I think you can only do it yourself using selfserve if you are changing plans? I don't think it lets you renew the same plan without going through the Moderator Team.
09-08-2018 01:25 PM - edited 09-08-2018 01:26 PM
If your account is suspended, send a private message to moderator for help.
09-08-2018 12:52 PM
Mod reply time is 24-47 hours at the moment. So if you are renewing just for data and it is urgent you could buy a data add-on .Or if your plan is not grandfathered renew(immideate plan change) a different plan and then futuredate your current one.
09-08-2018 12:49 PM - edited 09-08-2018 12:56 PM
Contact a moderator and they can help you with that. Include your phone number and account PIN within the private message to them.
