10-02-2018 11:27 AM - edited 01-05-2022 02:00 AM
I added wrong add-on by mistake . I wanted 15$ international long distance add-on . But added 8$ canada wide long distance add-on . My plan 40$ one already has canada wide calling . Can I remove this and replace with 15$ ?
10-02-2018 12:00 PM
Thanks for your suggestion .
10-02-2018 11:53 AM
@theSamratthere is a price difference between the two addons. In your situation I would do a manual topup of the difference between the two addons. that will speed up the process of upgrading the addon. The mods are pretty good about these kind of changes but its never 100% guarenteed.
10-02-2018 11:30 AM
@theSamrat, you are going to need the moderator team to do this account change. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code along with a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
