Regd usage for 2018
raghu
Hello,
Can someone help me to find out summary of usage by dollars for my phone with public mobilr
Thanks,
Raghu
12 REPLIES 12
@raghu Do you have your history payment now?
raghu
Thanks for your information
Raghu
@raghu wrote:
I was trying to find out how much I spent in 2018 on Cell phone the print out shows only from July till Dec, how can I see for the full year.
Raghu
Unless you started in July, it doesn't sound quite right. I believe the payment history can go back a year. So end of March 2018. Not all 2018 if you started before then.
@raghu wrote:
No I do not remember which credit card I used nor plan that is my confusion.
Raghu
Ok so write a message to the moderator is the only solution.
raghu
Raghu
Raghu
Perhaps you can have this information with your credit card? Or do you remember which plan did you have during the year and calculate...?
raghu
Raghu
@raghu wrote:
Hello,
I tried what you said it shows only last 6 montha not the full year.
Raghu
If you want more you can ask to the moderator (I don't know if it's possible) here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain what you want. Waiting time is few hours to 2 days.
raghu
Hello,
Raghu
srlawren
@raghu wrote:
Hello,
Thanks,
Raghu
@raghu what's a "Regd" and what info exactly are you looking for here?  Summary of usage by dollars doesn't make it very clear.  EDIT nevermind I guess @Lieux gave you the info you wanted.  I still have no idea what it was you wanted, but glad you're satisfied.
raghu
Thanks for getting back so soon.
Raghu
Lieux
@raghu wrote:
Hello,
Thanks,
Raghu
You can go in your self serve account and click on the tab PAYMENT..and HISTORY PAYMENT.
