Regard subscription change
Jinuk
Good day,
I'm considering changing my subscription (CANADA-US PROMOTION 5G / $40 / 75GB).
I'm wondering if I can use 5G data in Canada and the US with no any other fees when I travel with the new subscription.
If so, I will change immediately.
Thank you in advance for your help.
@Jinuk  Yes absolutely you can
hairbag1
@Jinuk
additionally...make sure your cellphone has VOLTE enabled by PM for best talkability while in US....otherwise your phone will need to use 2G for talk in US.
Dunkman
Correct.  There will no additional fees when you travel to the US with this new plan.
If you are changing plans, we usually recommend change at next renewal date.  Since Public mobile does not pro-rate plans if you change or leave earlier.
