Refund
Mam72
Cant transfer PH# would like refund or credit
Ruth435R
They told me refund is possible, but must contact bank. which isnt really how refunds work.
slusagm
Credit ok but not refund.  but you bought wrong add-on or what happened ?
TO ask for credit back, ask PM by ticket
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
Chalupa_Batman
Hello @Mam72
If you are having trouble porting your number, you can create a ticket for a CS Agent to assist you.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
Please note, your phone number you want must be on an active account.
golfball
Why can't you transfer your number? Is it not possible or some kind of error? If you need help or to ask for a refund you can contact support.
To contact support you can submit a ticket through the chatbot by pressing the chat bubble in the bottom corner and typing in "submit a ticket" and selecting "Contact Us".
If that doesn't work you can message support directly from here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
hairbag1
@Mam72
why can’t you port your number ? Consider taking a new number ?
