07-27-2019 09:57 AM - edited 01-05-2022 06:08 AM
07-28-2019 12:35 AM
@Meritt_cahoose wrote:I purchased the wrong data add on, could I get a refund for it to purchase the right one?
If you bought wrong amount of data, I would just use it when needed. There are no refunds.
07-27-2019 10:31 AM
Was it a roaming add-on and you aren't going to the states? You didn't use any of it?
They wouldn't likely give you a refund of your money. They would more likely credit your Available Funds.
07-27-2019 10:01 AM - edited 07-27-2019 10:03 AM
Try contacting mods
Good luck
