01-26-2026 02:50 PM
02-03-2026 04:38 PM
Thank you for the escalation. Situation handled by CS_Agent
01-31-2026 01:17 PM
This escalation is usually reserved for Monday to Friday, but I saw this agent respond to a couple of threads this morning. Due to the backlog of service tickets, hopefully this service will be working today. They will private message you directly.
01-31-2026 12:58 PM
That would be great! I hope they can respond as soon as possible because I can’t reply back when I’m at work. Thank you for your help!
01-31-2026 12:55 PM
Looks like your PM account was not set up properly and also porting issue. I will try to escalate to CSA_PM, who hopefully will private message you in the next 1-2 hours.
01-31-2026 12:51 PM
I can’t make calls nor receive calls. Same with messages. Called my old provider, said it was active. I don’t know why this happens, and it’s been a week now, I stopped receiving messages from work. sigh
01-31-2026 12:45 PM
01-31-2026 12:44 PM
Can you confirm if your PM sim connected to the network? Can make outgoing calls ? Data works?
It is porting problem if you just cannot receive incoming calls. But if not connection to the network at all, it is sim provisioning
01-31-2026 12:42 PM
It’s been a week already and no help, no solutions that are working. Imagine checking and logging in multiple times a day, doing the same process to confirm your identity but it just always ends like that. Phone still no service. Very inconvenient. @CS_Agent
01-26-2026 09:06 PM
i didn’t know it can be this frustrating :(. just need the money back now because i’ve been gone for days without phone service and only depends on work wifi. very inconvenient. i’ve been trying to message them for how many times already within the past days, still got no reply or anything. thanks tho.
01-26-2026 02:55 PM
tagging CS agent won't help, you need to message them
Message them to try to get the service working, and ask for refund if they cannot help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
