01-04-2021 11:54 AM - edited 01-05-2022 04:43 PM
I have six phone numbers listed under “Refer-a-Friend Reward” but only get $4 per month referral rewards. What’s the deal?
01-05-2021 01:17 AM
@DDM69 wrote:This has been a common problem/glitch for a while now. Referrals appear then disappear. Very annoying but the price is right here at Public Mobile 😁
They aren't real. It annoys but the disappearing referrals are fake. If they forget to take the fake referrals aways, you could get more rewards than you earned, so ignore it. When more numbers are there than the reward shows, the difference is from suspended accounts.
01-05-2021 12:02 AM
01-04-2021 11:44 PM
01-04-2021 12:51 PM - edited 01-04-2021 12:51 PM
@guangqin Believe can also be affected if any referral accounts went into suspension before renewing.
01-04-2021 11:56 AM
There was a clean up by PM. If any accounts were no longer active then you would lose your referrals.
01-04-2021 11:56 AM
@guangqin wrote:I have six phone numbers listed under “Refer-a-Friend Reward” but only get $4 per month referral rewards. What’s the deal?
The deal is...sometimes the refer-a-friend reward glitches out. If you're certain all 6 friends have active PM accounts, then contact the moderators...they'll make it right for you.
