Referral number
01-16-2025
02:14 PM
01-16-2025
06:44 PM
computergeek541
01-16-2025 07:54 PM
Thank you for the information. I have found it!!
01-16-2025 04:34 PM
01-16-2025 02:40 PM
if you use the app, the friend code can be found easier on the app. Login the app and go to Account page and it is under My Referrals on the top
or if you are using browser, you can also get it via the Rewards site:
01-16-2025 02:16 PM
go to your My Account , and the code is right there on the banner "Sharing is Caring"
or go to My Referral page and the code is there at the Sharing is caring banner too
