New sim card
AL991
Hi
To activate my new sim card I need to input a code sent to my new number. I am not receiving this code after several attempts
Can you help?
Thanks Alex
AL991
I will send them a message.
You're correct I am not getting another option other than to resend the code.
ORNGNBLK
@AL991  I recently saw this happen to someone. They were trying to subscribe via the web page. You can only subscribe using the app, so download that and ensure you are using it to subscribe. Hope this helps
Phil_Adelphus
@AL991  This is a new activation?  If so, send a private message to customer support using this link
You're probably being offered "resend the code" when you try?  Once you are up and running it will change to "didn't get the code" which offers email and voicemail options.  But I'm guessing you're not seeing that at this stage.
hairbag1
@AL991
do you get the option to have it sent to your email address ?
