08-03-2023 11:35 AM
Is there any way to see the list of people you've referred on the new app and website?
6 hours ago
They very clearly stated on the NEW site. This is the old site
08-03-2023 01:28 PM
08-03-2023 12:07 PM
@XxdanxX if your friend just joined , it might take couple days to show up on your end
For your friend who you referred, ask him/her to login to My Account AFTER 72 hours of activation, there should be a $10 credit on the Available Fund there
If your friend does not see it, ask your friend to open a single ticket for both of you with PM support and they can manually apply the rewards
08-03-2023 12:04 PM
There is no information about people I referred just a copy link to refer people this new system doesn't seem to show anything but my acquired points and redemption
08-03-2023 11:54 AM
login to My Account, click on the Rewards tab and then click Go to Rewards portal, it will show you the rewards you have. The amount showing on Friend Referral will be the number of referrals you have. That number could be slightly differet from friend referrals point (if you are on Public Points) you got in the month as one or more of your referees could have their account suspended at the time you renew your plan
08-03-2023 11:46 AM
How do you see how many ?
08-03-2023 11:40 AM - edited 08-03-2023 11:43 AM
@XxdanxX Check in your rewards portal . And you can see the phones numbers you referred
Add should look something like this
08-03-2023 11:38 AM
if you are on the legacy rewards system, YES you can
if you are on the current Public Points, then NO. They will only show you how many, not the details
08-03-2023 11:38 AM
Customers on the old rewards system can. Customers on the points system can not. On old rewards, in the rewards page, click on the refer a friend line and the details will show.
