11-27-2022 09:18 AM
11-27-2022 10:06 AM
Pass the code to your friend and let him enter it during signing up. Press on Copy button on the screen and paste it in email/sms to your friend. Let him do the same (copy/paste) to avoid any common typos (0 - O, 1 - l, etc.).
11-27-2022 10:04 AM
@SG12 wrote:"How can I use the code for referring a friend."
When your friend activate in activate page, your friend put in your referred code which you can find it in your self service account that you sent to him/her by text or email.
11-27-2022 09:26 AM - edited 11-27-2022 09:29 AM
To get to the code, sign into your self-serve page, and at the bottom right, it's part of the cycling messaging.
Tap the COPY button when there. (a screenshot is certainly helpful, @Metal1967, however may not allow the receiver to discern certain characters). Then, send the code via SMS or e-mail to the person you're referring and have them PASTE the code into the field on their activation page.
Failing to do this may result in certain characters being confused for others (such as zero's and O's, and one's and I's, etc...)
11-27-2022 09:21 AM
@SG12 Screenshot your code so they get it correct and give it to your friend to use at sign up
