05-18-2022 07:59 AM
last month I used my refer a friend code when I was helping my mom set up her phone with public mobile. I checked to see if I had gotten the $1 off in my rewards but I didn’t see anything. So I thought that maybe it wouldn’t show till next billing date. The next billing date was yesterday and my refer a friend was still showing $0. And my mom never got her $10 dollars off. It’s a bit frustrating because I can’t find anyone to contact about it and the refer a friend system was one of the main reasons I recommend public mobile to my mom. I don’t know if I put the code in wrong or what happened but I feel like I should be able to get the reward somehow. If anyone could help that would be great.
05-18-2022 08:36 AM
No worries, this happens a lot and can be easily sorted out. It may have been a typo or a system error. Connect with a CSA so they can manually add this for both you and your mom.
05-18-2022 08:10 AM - edited 05-18-2022 08:11 AM
@klwadsworth03 No worry, PM should be able to add it back. Just need to open a proper ticket with them
Make sure you mom has a Community account and a Self-serve My Account login , have your mom (or you help her using her credentials) to open a ticket with PM Support to check the for rewards on both of you.
To open ticket with PM
1. If your mom have access to My account: At https://publicmobile.ca/chatbot.
2. If she doesn't have access to My Account or have trouble with Chatbot: Private message CS Agent with your mom's Community account at:
