Refer-a-friend, save $25
Lehaha
Is it for every friend you referred, you can get $25 for each one? Or you just have one chance get $25?
darlicious
@Lehaha
There is a glitch applying the credits when the promotions overlap.
Lehaha
Thanks
dust2dust
As far as I understand so far:
1 - you 5x5, them 5x5
2. you not, them 5x5
etc.
What we're still trying to figure out is when they do another promo whether you can start up another line #1 5x5 while the prior is ongoing. Maybe @darlicious has some more info on that front.
HI @Lehaha
for you to get $5x 5 months, only one
but you can refer more than 1 friend and they can all get $5 x 5 months (again, you will only get it once)
RossN
@Lehaha hi the first person you refer you will get 5x5 after that you will get your regular 1 dollar per cycle,but they will still get thier 5x 5
