Data add-on not working
Daveby
I purchased data as I have exceeded my use for the month but it isn't working. Not sure how to fix it. Any help is appreciated.
1 REPLY 1
@Daveby   login to My Account using Incognito mode and make sure the add-on you purchased is there
Reboot your phone once and make sure there is no data limit set on your phone Mobile Data usage page that blocks the use of data
