Refer a friend rewards
Rob1963
I know there is a place where you can see the cell numbers you have referred or partially anyway. Can someone please tell me how to find it?
If you just received some mystery “CHa-Ching” texts for successful referrals over the weekend and are wanting to check it out.... they are likely glitches in the system.
AE_Collector
Log in to your self serve account. Go into the rewards section and expand that to get a further breakdown of all rewards on your account. Click on the arrow next to the refer-a-friend credit amount.
Hi there - yes, there is. 🙂
Under My Rewards tab in your OVERVIEW, SELF SERVE account.
Then click the arrow pointing to the right, the numbers will drop down. Showing only the last 4 digits:
