02-03-2021 06:09 PM - edited 01-06-2022 02:01 AM
Who can help me with this?
02-03-2021 06:29 PM
Thanks for the quick and precise reply, that helps... I can see it now.
02-03-2021 06:27 PM - edited 02-03-2021 06:30 PM
@Saffoto when did the new activation happen?
Last time I refer my family, 3 months ago.. the new line see the credit within first week, and I see mine 2 days after.
so, if the new line just activated within this week.. maybe at least wait another week before you open a ticket with mod
02-03-2021 06:11 PM
@Saffoto- Are you the one who was referred? Or the one who referred someone else? If you were referred, the $10 should show up within a few days, but definitely before the first renewal. If you are the one who referred someone, then it will show up only at the next renewal(during renewal process).
02-03-2021 06:11 PM
@Saffoto wrote:Who can help me with this?
@Saffoto If you used a referral code from a friend, you will see it in your account within 3 days. If your referral code was used it should show in your self serve
Click on "My Rewards" and it opens to this;
Click the small triangle and this is what you will see;
