yesterday
I just redeemed 10 points for 300 international minutes in ERROR! Can I reverse this redemption and get my points back?
yesterday
Thanks for your input!
yesterday
Hi @HazelG !
I’ve been there! I did the same thing and unfortunately there’s nothing that you can do, I tried contacting CS but they couldn’t help… at least you didn’t waste "real" money!! And I think the minutes will stay in your account forever, so it could come in handy one day, who knows?
yesterday
I am not sure if you get a return for the points as when you picked the item from the catalogue. It ask you to confirm your order but worth asking a CS_Agent to help you change to the correct item.
yesterday
hi @HazelG
PM is a prepaid carrier, they don't usually provide refund. But for situation like this, they will usually help out, reverse the transaction and put the funds back to your account and you can use it for other purchase.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
