Recovering Deleted e-Sim
Immune
Want to completely re-set my phone that would also delete my e-Sim. How would one re install the account e-sim?
@Immune wrote:
Thanks for info  ---- Initially a few months ago had purchased a physical sim from Amazon that I now chose to switch to and thus avoiding tense moments -
hi @Immune just to add (but probably too late) , iPhone has a feature to put aside the eSIM and reset the phone and use the same eSIM back.
@Immune  In that case if you want to switch from eSIM to physical SiIM  one just has to log into there account profile page and sim swap number like this
SIM  SWAPPING  profile tabs
Can do it on the app also I actually prefer physical sim over eSIM for this very reason . And I like to switch and try different devices often so I stick with physical for long as I can until we all finally switched over to eSIM or some other new technology that will. Ultimately come along
Immune
@Immune  you just simply need to log into the PM app with phone  and rebuy esim . You should get credit back for the esim in check out if not contact support
