04-21-2024
10:04 PM
04-22-2024
12:49 AM
computergeek541
Hi there,
I am an Australian traveling the US, heading to Mexico and then Canada soon. I have purchased a voucher on recharge.com for public mobile but am unable to activate it. When I call 611 it only calls tello as I have a tello sim here currently. If I take that out it won’t call at all as I obviously don’t have a sim. I just want to know how to activate it when I land in Canada! I’m quite confused so any help is much appreciated!
04-21-2024 11:30 PM - edited 04-21-2024 11:31 PM
you can actually load your voucher before you are back in Canada
Download VoIP app TextNow (or Fongo if TextNow does not work). Setup a new and free Canadian number with the app. Then call 1.855.4PUBLIC with the VoIP app and you can load the voucher you got from recharge.com that way
04-21-2024 10:54 PM
Thank you for your reply! So I won't be able to activate until I'm in Canada? And once I call that number when I want to top up, do you know if I should be able to use my recharge.com voucher?
04-21-2024 10:13 PM - edited 04-21-2024 10:20 PM
@Matilda102938 - You will need a Credit Card / Debit Card to activate. So you can get a Vanilla Prepaid Visa card to activate.
Also when you top-up call 1-855-4PUBLIC on any phone to load up balance once activated.
Also you will have to activate within the app - which your region must be set to Canada to get the app unfortunately.
Also if you are on Android you can download the Public Mobile APK here: https://apkpure.com/public-mobile/com.telus.publicmobile
