Recently switched to a 4G plan but still showing 3G on phone
12-04-2022 01:24 PM
Hi support, recently switched over to a 4G plan and phone is showing a 3G connection and has connection issues when making and receiving calls. I don't think it's throttling, using an Iphone 11 so need some help here. Could it be the SIM card or an Iphone setting? Please advise, thanks.
Service
12-04-2022 06:01 PM - edited 12-04-2022 06:02 PM
@Outdoorsman wrote:@RPappas hi there is a cache issue with accounts,use a different browser in private or incognito mode sign back in anD see if it clears up
Self Serve website caching issues don't influence the way a phone connects or the type of network that the phone connects to.
12-04-2022 01:37 PM
@RPappas In addition to what @Outdoorsman said to do. Another thing is that iphone's allow you to use just 3G or LTE and if there is not LTE it goes down to 3G. Go to settings then Cellular then Cellular data options and in voice & data select LTE. Another thing is that in order to get the speed of LTE (LTE is another name for 4G) is that it takes 48 hours after switching to the 4G plan to actually get the speed.
12-04-2022 01:35 PM
@Outdoorsman that shouldn't affect calls, though, right? It's mostly call connections that are dropping
12-04-2022 01:26 PM
