03-15-2023 12:40 PM
I tried to call my cell phone using my alexsa and all I get is a busy signal. I tried my txt plus it rings. My dad tries to call he gets the busy signal but I have gotten other calls. Why does this happen and how can it be fixed?
Service
03-16-2023 06:22 PM
Yeah I had lots of help already porting and starting up presented some issues I guess I'll have to open another ticket thanks
03-16-2023 01:47 AM
Did you leave the old sim in a phone and reply to the confirmation text from the old provider?
Try the number in the link to re-trigger the port. Put the old sim in a phone and wait for the text to reply to.
03-16-2023 01:30 AM
@Cat4 wrote:I ported my phone number I have tried rebooting and can try again I suppose.
You can't just try again using the Self Serve account. You will need a CSA to help you fix the porting. The chatbot link is at the bottom of page. Use that to make a ticket.
03-16-2023 01:06 AM
03-15-2023 12:45 PM
@Cat4 Did you just port your number from another carrier or have you been using PM for a while? A simple thing, have you tried to reboot your phone?
